Xt power draw
- Site Admin
- Has liked: 435 times
- Been liked: 260 times
Re: Xt power draw
2A is what the charging converter is rated atraesewell wrote: Tue Apr 11, 2023 6:18 pm Thank you for the link, however, there doesn't seem to be a definitive answer, I want to know what size fuse to use in my Fuzeblock.
5A would be fine
I would be going 10A to be on the safe side
- Site Admin
Re: Xt power draw
In reality you can put any fuse above 5A and if it blew I would be worried as its indicates a fault
As I say 5A will suffice just carry a 10A spare just incase
- Has liked: 144 times
- Been liked: 139 times
Re: Xt power draw
Sorry to say that the XT power consumption is not listed in its manual or anywhere on the Interwebs that I can find. However, I do still have my zumo 660 manual and it says maximum consumption is 10 watts. So crank in a fudge factor for the XT having a brighter screen and call it 12 watts as a semi-educated guess. That would come out to one amp draw from a 12-volt battery ( a bit less when the engine is running and the alternator is supplying 14 volts).
