Testing my new XT and it sure can do some strange routing. But for now my biggest head scratcher is a blue icon that shows up on a route that the XT created. It is on an interstate highway (divided motorway for you folks) and there is a portion of the highway with a black stripe showing, which I assume is traffic congestion. At the start of that segment there is a blue rectangle with a white international keep-out circle with slash. What does this mean?
It only appears with a route in progress and turning off all traffic options does not make it disappear.
EDIT: I switched to car mode, set all its prefs to be the same as motorcycle, and two things happened, but only after I switched back to motorcycle and the XT asked if I wanted to recalc because some avoidances had changed. Here are the changes: the nonsensical routing near the start (took me a couple of miles down several local roads to get to the highway when a closer highway entrance is a mile from my home) went away and it erased that black stripe and blue icon.
2nd EDIT: After studying the manual, the closest to this mystery icon I can find is the blue rectangle with various white parking symbols displayed, depending on what features are enabled in the Parking function on the XT. Even the black stripe appears to have some Parking meaning. I did not have any of that enabled, but apparently the XT thought I did and after a restart and the mode change it came to its senses. Maybe?
