- 15,000 points per track
- 30 via points per route (including start & end)
- 125 shaping points between via points
When Sending or Creating Files for the zumo XT, Keep in Mind the Following Limitations:
Unlimited GPX files
Unlimited waypoints
Unlimited geocaches
Unlimited routes
Maximum of 200 waypoints per route
Unlimited saved tracks
Maximum of 10,000 points per track
2,000 archive tracks
Each GPX file can contain a mixture of waypoints, geocaches, routes, and tracks. If the GPX file containing a waypoint or geocache is deleted, the waypoint will no longer be available on the device. When utilizing routes, only 50 points can be used for on-road navigation.
Besides the fact that there is no mention of via or shaping points, the maximum 200 waypoints per route and 50 max usable navigation "points" make no sense, the track point limit seems too low, and I have no idea what the difference is between a waypoint and a geocache.
Does this web page have major errors or am I just suffering from dementia?
