Erasing Data
Scarecrow
Been liked: 28 times
Erasing Data
Post by Scarecrow »
Hi Guys
Is there a way to ease all routes and waypoint from my XT without doing a full factory reset.
Thanks in advance
Del
simoncrewe
Has liked: 47 times
Been liked: 38 times
Re: Erasing Data
Post by simoncrewe »
Scarecrow wrote: Tue Jun 07, 2022 5:55 am Hi Guys
Thanks in advance
Del
Personally I would delete everything via Garmin Explore and then re - synch the XT with Explore.
Re: Erasing Data
If you don't use Explore...
For deleting routes: Go into Trip Planner > Saved Trips the tap the spanner icon (Wrench). The resulting menu contains an option to delete trips. There will then be the option to select all or individual trips.
For saved waypoints: Go into Where To? > Saved (or Favourites), tap the hamburger icon, the "Delete Saved Places".
Any routes stored on an SD card must be deleted manually using a file explorer while connected to a computer.
Rofor
Been liked: 83 times
Austria
Re: Erasing Data
Post by Rofor »
Peobody wrote: Tue Jun 07, 2022 1:22 pm Any routes stored on an SD card must be deleted manually using a file explorer while connected to a computer.
Or while you be connected to Basecamp...
Bye, Robert :)
Scarecrow
Re: Erasing Data
Post by Scarecrow »
Thanks Guys
Ever helpful as usual
Re: Erasing Data
Note you also need to delete any .gpx files in the GPX folder
