Missing data following update
AntoineLeRenard
Post by AntoineLeRenard »
Just prior to undertaking a trip around Brittany with friends in April I updated my Zumo 590lm as required. It wasn't until I was using the device that I noticed that it would no longer indicate the mileage to the set destination, and the TPMS feature has disappeared, although I do not use it currently.
As such, can anyone provide me with advice as to retrieve or reinstall the distance/mileage data on the screen, and also the TPMS feature too?
I apologise if this query has already been asked in a different thread.
ALR
Has liked: 374 times
Been liked: 383 times
Re: Missing data following update
Issues like this after an update are normally resolved after a master reset.
AntoineLeRenard
Thank-you for your prompt advice. Again showing my lack of knowledge, how do I go about a master reset?
1. Touch and hold the lower right hand corner of the touchscreen
2. Power the device on
3. "System" will appear on the screen for approximately 30 seconds
4. Remove your finger when the screen displays Loading..."
5. The device will now reset.
AntoineLeRenard
Many thanks for your advice. I will give this a go.
