New Firmware for Zumo XT
- simoncrewe
- Has liked: 47 times
- Been liked: 38 times
- Has liked: 183 times
- Been liked: 166 times
Re: New Firmware for Zumo XT
I have updated mine from 6.30, it installed properly.
Did it fix or break anything? Time will tell.
- xt64.jpg (18.33 KiB) Viewed 6652 times
I just updated my XT and everything seems to be working properly, including the three dots in the lower right corner in map mode.
The first thing I did was to disable the helmet law notification!
Yes, I had the same problem. I resolved it by performing a reset and installing the additional updates that came up shortly after.raza wrote: Thu Apr 14, 2022 9:19 pm New update with a new bug in the program!
In the map view, click on the lower right corner (three vertical dots) - the device freezes and resets!
Who else is this happening to?
What are these additional updates?Grispoil wrote: Fri Apr 15, 2022 4:34 am Yes, I had the same problem. I resolved it by performing a reset and installing the additional updates that came up shortly after.
Thanks
Anyway my file size is " 69 MB" ,no 72,48 MB.The file sizes are different and they depend on where you live? ( I live in Italy)
giuseppe66
- Has liked: 27 times
- Been liked: 9 times
Ufficialmente sono tre come indicato. Non ufficialmente lo scopriremo sulla strada..speriamo abbiano ripristinato almeno le smart notification con android 12..Raf wrote: Fri Apr 15, 2022 8:01 amWhat are these additional updates?Grispoil wrote: Fri Apr 15, 2022 4:34 am Yes, I had the same problem. I resolved it by performing a reset and installing the additional updates that came up shortly after.
Thanks
colirv
- Has liked: 66 times
- Been liked: 64 times
- Contact:
Well I had to downgrade from 6.3 to 6.2. I'll hang on and see what people make of 6.4!
