This is what I think;
BMW IV = Zumo 660
BMW V = Zumo 590/95
BMW VI = Zumo XT
I intend to hire one on holiday. I know that Jog weel on GS will not work if I use Garmin
Corrections or confirmation welcome
BMW Nav vs Garmin decode part numbers
- Been liked: 5 times
- Site Admin
- Has liked: 320 times
- Been liked: 156 times
Re: BMW Nav vs Garmin decode part numbers
They are similar to what you have posted but not the same
A lot of people say the XT is superior to the Nav 6
Thanks Stu,
My objective would be what BMW cradle would run what Garmin. When I was in Italy I ran my 660 on a GS 1200 cradle ** . No jog wheel but was OK.
My issue is that loading an SD card with my routes onto a hire unit can be hit and miss. In Portugal it took forever to load.
** It did work until I realized I had not clicked it into place and it popped off at 80KMH into Giuseppe’s Fiat !. He was not happy but saw the funny side in the end.
- Site Admin
On that basis I believe the 660 will fit the cradle and the nav V and VI
I don't believe a 590/595 fits as I believe the power outputs/inputs are different
The connecting pins are the same for 660, 590, 595, Nav V and VI. The case dimensions vary, so I'm pretty sure a Zumo 59x will not fit an RT's factory GPS mount, but might work on a GS. The NAV VI is more like a 595 with an improved screen. The XT uses totally different connections and mount, though there are adapters available to use the BMW cradle for mounting and power.
