Map updates on PC vs Zumo XT
I downloaded maps via Garmin Express to my PC so I don't need to have the unit connected always when working a long route. Was wondering if the maps on the PC will be updated when the maps on my Garmin Zumo XT are updated?
- Been liked: 1170 times
Re: Map updates on PC vs Zumo XT
I haven't tried the new Express 7.9.0.0 to install maps, but it normally gives you an Options menu where you can specify to install them on the computer, the Zumo or both.
- Has liked: 195 times
It is important to know that the map update on the PC will not happen automatically. You must intentionally tell GE to do it. Like jrheath, I haven't done a map update with the latest version of GE but have checked to verify that the option to install a map to a PC is there so if you aren't offered the option to install to the device and a PC you should be able to install it to the PC as a separate action.
