New 395 won't power up. On the road and without my routes...
Andyman6770
Post by Andyman6770 »
This afternoon all was well. First trip with my 395 after many thousands of perfect miles using a 550.
While ironically on US 550 going north to Durango i could not get my 395 to ignore a waypoint that was a scheduled detour on my intended route. So while moving, i took the unit out of the cradle. The screen went dark and it will not power back up. It had been in use for several hours, shoud have plenty of juice but nothing is working.
Anyone experience this? Anyone know a remedy?
Thanks in advance.
Andy
Re: New 395 won't power up. On the road and without my routes...
When my 595 goes into sulking mode I disconnect the battery for a few seconds, then it behaves normally.
Try pressing and holding the power button. Eventually it'll start up, may need up to a minute.
Sounds like 2 different problems:
1- I found with my new 595 it does not like using "motorcycling" when following a pre-designed route. It wants do do all kinds of stoopit things. Try changing it to "automobile", it behaves very well that way.
2- Does the 395 suffer the same battery plug deficiency as the 590/595? Anyone? Anyone? My new 595 lasted about 6 minutes on battery power on a good day. I thought it was a crap battery and I was going to have to fight with Garmina, send it back, etc. until I was directed here -> http://outsider-adventure.blogspot.com/ ... y-fix.html
Has liked: 435 times
Been liked: 260 times
rbentnail wrote: Mon Jul 30, 2018 1:59 pm Does the 395 suffer the same battery plug deficiency as the 590/595? Anyone? Anyone?
That's my solution that's also posted here viewtopic.php?f=12&t=2 :mrgreen:
Although [mention]Outsider[/mention] has figured out a better solution as the pins touch both sides
Outsider
Post by Outsider »
I guess they’re all using the same type of battery/connector so will have the same issues.
In a pinch (on the road) I’d lightly push a thin pin into the connector holes (as others have mentioned).
[mention]Stu[/mention] is the man, though [emoji4][emoji1360]
- Outsider
My occasional adventures: www.outsider-adventure.blogspot.co.uk
My other passion: www.droidbot07.blogspot.co.uk
