(Another)Memory Card question
Scarecrow
Been liked: 27 times
Post by Scarecrow »
Hi again Guys :roll:
another Techi question
Can I save routes & music on the same memory card?
Milu23771
Italy
Re: (Another)Memory Card question
Post by Milu23771 »
Of course, inside the "Garmin" folder, the routes, tracks and waypoints are saved in a subfolder called GPX, while the music files in another one called MP3
Scarecrow
Post by Scarecrow »
How do I do it ?????? :oops:
Scarecrow
Post by Scarecrow »
Anyone ??
Iris
Been liked: 14 times
Post by Iris »
I think you have to do it while utilizing file explorer. You should be able to simply copy and paste, or drag and drop.
Milu23771
Italy
Post by Milu23771 »
If your micro SD has already been inserted into the Zumo, it already has a folder called Garmin in the main root, and if you have imported routes, it has also generated a GPX folder that contains them. If so, connect your Zumo to your PC and it will appear as a mass storage device in the Windows Explorer. Selecting it you will be able to see internal memory and SD card. Open SD card, open the Garmin folder and create a folder inside it and name it MP3, after which you can fill it with your favorite music. If the card is blank, after formatting it in Fat 32, you can directly create the Garmin folder and the MP3 subfolder, connecting it to the PC with a normal card reader.
Scarecrow
Post by Scarecrow »
Thank You
