Is there a way to disable Foursquare on the XT?
spike747
Post by spike747 »
I'm surprised a Google search found nothing on this subject. Its so annoying this foursquare garbage. I'm not logged into it on the Garmin drive, so it must be in the maps. I really don't want it there. I was hoping I'd find it in the map layers, but I didn't see it. I'm hoping I can disable it.
Thanks.
simoncrewe
Has liked: 47 times
Been liked: 38 times
Re: Is there a way to disable Foursquare on the XT?
Post by simoncrewe »
spike747 wrote: 07 Jan 2021 07:16 I'm surprised a Google search found nothing on this subject. Its so annoying this foursquare garbage. I'm not logged into it on the Garmin drive, so it must be in the maps. I really don't want it there. I was hoping I'd find it in the map layers, but I didn't see it. I'm hoping I can disable it.
Thanks.
Have you looked in the device directories to see if you can see it listed - If you decide to delete it, back the unit up first to avoid 'bricking' it.
Alternatively give Garmin support a call.
Personally I do not use Foursquare & it does not bother me it being there.
Has liked: 379 times
Been liked: 384 times
Should be in your myMaps. Just deselect it
groundhog719
Has liked: 12 times
Been liked: 5 times
Post by groundhog719 »
Not in maps (or anywhere I could find on the GPS) - I could not find a way to stop it either.
Have you looked in the .system directory?
Note that directory may not be visible, if not see http://forums.gpsreview.net/discussion/ ... my-dezl760
Telstar 2112
Post by Telstar 2112 »
LIke someone said above, it should be in your Settings. From home page (before Viewing map) Click Settings, Map & Vehicle, scroll down to mymaps, and deselect it. At least on mine.
