Zumo 590 Splashscreen
Steve1020
Post by Steve1020 »
Is it still possible to change the startup screen on the 590LM? I just upgraded from my trusty Zumo 550 and had the ability to put my contact info on a .bmp and pick that as a splashscreen n case it ever was 'lost'.
I can't find anything on Google to indicate that this is possible, but did find 1 link that had an answer for the 595, but unfortunately, would not work on the 590.
Thanks!
Steve
Imskier2
Has liked: 4 times
Re: Zumo 590 Splashscreen
Post by Imskier2 »
There is no way that I'm aware of to change it on the 590.
2022 Ultra Limited
Mean Green Machine
Radioactive Green/Vivid Black
Arizona
VA3TWT
Has liked: 25 times
Post by VA3TWT »
That's too bad. I was hoping to do the same as Steve1020. Had a custom screen on my 550.
Gord
Zumo 595LM
2010 GL1800 Goldwing
blacktiger
Been liked: 3 times
Post by blacktiger »
Yeah seems to be another of Garmin's improvements. Just like not providing the ability to have a PIN security on start up.
bogiediver
Has liked: 5 times
Post by bogiediver »
You can't change the initial splash screen (i.e. the 'Garmin' name) - however you can hack the warning screen text that comes up next... and text on most screens...
Attached a PDF of the steps and examples...
zumo 590-595 - Text Hack Notes.pdf
(233.94 KiB) Downloaded 1798 times
FWIW
AnotherHonda
Post by AnotherHonda »
Thanks Bogie, Just upgraded from a 345/395 to a 595.
Been trying to do a splash screen like I had on my old Streetpilots and Zumo 220.
I've just changed the warning screen so far.
Now I'm trying to remove/change the Automobile Association Roadside Assistance information on the Where Am I? screen.
Would be better if it was my Insurance company's recovery details, and possibly if I can change the logo, but I guess if the "Garmin" splash screen can't be changed, the "AA" logo can't be changed either, but changing the contact details would be handy.
88 XRV650J RD03 Africa Twin JDM #373/500
93 NTV650P RC33
99 ST1100AX SC26B Pan European 50th Anniversary #200
00 C90MT C90 Cub, 04 XL125v4 Varadero & 05 XL125v5 Varadero
biz
Has liked: 25 times
Been liked: 25 times
Post by biz »
I know that this is an old thread, but just to add to it that a customer 590 or 595 splash screen CAN indeed be done - I've just done it. :-) The technique detailed here:
https://www.gpspower.net/garmin-receive ... a-etc.html
does work for the Zumo 590 and 595, but the file size is important. On my 590 with 595 4.60 firmware, 25kb was too big, 10kb loaded happily. I don't know what the actual limits are, though.
Jim
giuseppe66
Has liked: 27 times
Been liked: 9 times
Italy
Post by giuseppe66 »
Coloroby
Italy
Post by Coloroby »
Hi all
trying to change splash screen, opening the internal storage on my zumo 346(396) no *.rgn or *.cgd are present or visible, also with "show hidden files" and "show system files" both enabled
Do you know were i can found that file?
Tanks
biz
Has liked: 25 times
Post by biz »
Not familiar with those Zumo models, so I can't say - but as you'll have seen, I managed to do it on a 590/595 a couple of months back, so keep researching. I found https://www.navitotal.com/ a good place to get help. Good luck!
