I'm using Sena Smart HJC 20B in two helmets, where I was previously able to do music sharing routed to my primary headset to the secondary with no problem.
I cannot share music to the secondary headset now. I have my phone and both headsets paired with the Zumo XT. It shows "media audio connected" on the Bluetooth profile on the Zumo for both. However, the intercom works between them as before.
I cannot find any solution as to what killed this function. What setting in the Zumo would be stopping this function now?
Thanks for any ideas or help.
Can No Longer Play Media Audio to Two Headsets
- Has liked: 421 times
- Been liked: 922 times
Re: Can No Longer Play Media Audio to Two Headsets
Did you ever find an answer to this problem ?
- lkraus
- Has liked: 70 times
- Been liked: 190 times
I don't think music sharing is a function of the XT, and I don't recall any method to pair the XT with two headsets simultaneously.
Perhaps you had been using the music sharing function of the Sena?
See the Sena manual, page 19:
https://oem.sena.com/hjc/documents/User ... 191011.pdf
