Why shouldn't change the speed field?
Re: Why shouldn't change the speed field?
I'm guessing you mean "can't" rather than "shouldn't", and apart from the answer being "because Garmin programmed it that" way I too wish I knew why they have made some of their UI decisions.
I've long wanted to at least customize a setting that allowed leeway before it went to alert-red. At night on my old 665 I couldn't even read the red numbers against the black background. Allowing me to set either a percentage over or raw scalar over would sure be appreciated. Ditto that for *under* speed, too.
