Learning and using Basecamp
alan sh
Has liked: 5 times
Been liked: 26 times
Post by alan sh »
Alan
kernowing
Has liked: 128 times
Been liked: 55 times
Post by kernowing »
Here's another that's worth a look if you're like me---still learning :)
2007 GL1800 Goldwing
Zumo 660LM
Fitz
Been liked: 3 times
Ireland
Post by Fitz »
That really is an excellent and thorough tutorial. Takes some time to get through it, but time well spent, in my view. I couldn't get the US examples to work (presumably because I had to switch to "global map" in BC to see the US roads, and I have a subscription only for Europe maps), but it was easy enough to replicate the exercises using bits of my own data, routes, waypoints, etc.
alan sh wrote: Mon Apr 23, 2018 9:07 pm There is an excellent tutorial here http://www.newenglandriders.org/GPS/Lea ... amp_PC.pdf
Alan
Moose
Been liked: 21 times
Post by Moose »
great read (a lot of reading) I have never used basecamp guess after all these year of using garmin I should learn it. maybe
kernowing
Post by kernowing »
I got frustrated a couple of times trying BC after having used Mapsource but although I don't use BC to its full potential, I do like it now and use it for all my Zumo routes. :idea:
Zumo 660LM
Has liked: 400 times
Been liked: 213 times
For me Basecamp was a pain! I could never figure it out!
I used a few videos which are the same as what [mention]kernowing[/mention] has posted
These helped a lot and once I learnt how to use Basecamp I will never go back
Has liked: 96 times
Been liked: 201 times
I too used the newenglandriders tutorial and found it enlightening. I then discovered that it's so much easier to not create a route, I could never get all the way through a creation before I messed it up. What I mean:
New Route button, pick your origin and destination, escape. Pick the hand button. Let Base Camp "create" the route. Now, using what you learned in the tutorial, use the editing tools- insert, move and erase- to MODIFY the route to be what you want. No muss, no fuss, done! Then, continue on with the tutorial: double click your route> move pts to roads, change name & color, etc.
Works every time for me, give it a try!
Has liked: 311 times
Been liked: 356 times
It's actually easier than that. You can just rubber band the route having inserted the start and end point and allowed BC to calculate the route. No need to use insert etc
To do so press Alt then click on the route ... you can then rubber band it to where you want.
Has liked: 96 times
sussamb wrote: Fri Jul 13, 2018 3:02 pm It's actually easier than that. You can just rubber band the route having inserted the start and end point and allowed BC to calculate the route. No need to use insert etc
I never knew that! And it works!! Geez, I feel like a dope.....
This is what I do now I just choose a start and end point and adjust the route to how I want it
