A "How To" Question about creating different Databases
Iris
Been liked: 12 times
Post by Iris »
I thought I saw this somewhere but now I can not find it. Does someone have a tutorial on how to create databases and once the databases have been created, how to backup the variety of databases so that if there is a system crash, you would be able to pull all the data bases back in and be able to see all folders and lists as they were created in BaseCamp.
I don't understand exactly how or where BaseCamp saves these files.
I do know that they are in the following directory (on my computer): C:\Users\Iris\AppData\Roaming\Garmin\BaseCamp\Database
But if I have multiple Databases, what files are the ones I need if my system crashes?
Not sure if I asked this question properly or clearly.
colirv
Has liked: 41 times
Been liked: 35 times
Re: A "How To" Question about creating different Databases
Post by colirv »
I may have misunderstood your question, but Basecamp creates a database automatically, located as you say.
I back up all of the files - less than 300KB in total. You can back them up anywhere. You can choose which database to use in Basecamp by going to Edit/Options/General. I actually locate my database in Dropbox, which means it can be shared by Basecamp on my PC and laptop.
Colin
BMW R1250RS
Iris
Post by Iris »
That’s fine for the default database which most people use only that.
I have created other databases that I can toggle between. For example: I have a FJR Rides, Dirt Rides, Hiking, Mountain Biking, etc., etc.
This way I toggle between my activities and I don’t have too many things sandwiched on top of each other. For example, I don’t want to take my FJR on Dirt Rides.
mzeist
Has liked: 33 times
Been liked: 31 times
Post by mzeist »
you can probably find your answers here: http://www.gpsrchive.com/BaseCamp/index.htm
Groet, Marcel.
Has liked: 311 times
Been liked: 356 times
If you name your databases appropriately it should be easy for you to back them up?
colirv
Has liked: 41 times
Post by colirv »
mzeist wrote: Mon Mar 15, 2021 9:40 pm you can probably find your answers here: http://www.gpsrchive.com/BaseCamp/index.htm
Good suggestion! The answer is at the bottom of the Data Management section.
Colin
BMW R1250RS
mzeist
Has liked: 33 times
Post by mzeist »
colirv wrote: Tue Mar 16, 2021 9:46 am
Yes, indeed. I intended to link to that section..
Groet, Marcel.
Iris
Post by Iris »
THAT’S IT!!!!
Thanks!!!!
