PONI killer application
SonnyTheMoney
Post by SonnyTheMoney »
Hello,
I have been a long time Zumo user. I currently use the 660 on my RSTD.
Recently I have started creating my own routes for scenic rides around Southern Ontario Canada. And I have encountered an issue I remember from my days at the old zumo forums site.
When drawing/shaping routes, it creates many PONIs Points Of No Interest. But these are announced audibly when riding.
I recall there was an application called the PONI Killer. Which you would run your. Gpx file through and it would remove the PONIs and leave turn directions.
Can I still get this?
Thanks in advance for any help.
~Sonny
Dusty ST
Has liked: 12 times
Been liked: 10 times
Re: PONI killer application
Post by Dusty ST »
I change them to not announced using Garmin Basecamp. IIRC you need to open the route, right click the point and select not announced.
Breezly
Has liked: 20 times
Been liked: 28 times
Post by Breezly »
Dusty ST wrote:
30 Jun 2020 11:35
That doesn't apply to the 660. Only newer units using the Tripplaner routing will utilize that info.
Breezly
Has liked: 20 times
Post by Breezly »
SonnyTheMoney wrote:
30 Jun 2020 10:29
Hello,
~Sonny
Try the link here:
http://www.fes-software.nl/zumo/unflag.zip
Who is online
