Replacement Mounting Bracket
Ray N.
Has liked: 12 times
Been liked: 3 times
Post by Ray N. »
UPS just delivered a replacement mounting bracket for my Zumo XT. It seems to fit a little snugger.
2021 Goldwing DCT Tour - Zumo XT
axamax
Has liked: 7 times
Been liked: 10 times
Re: Replacement Mounting Bracket
Post by axamax »
Still trying to get one from Garmin UK.
Keep losing power from the mount.
simoncrewe
Has liked: 47 times
Been liked: 38 times
Post by simoncrewe »
axamax wrote: Wed May 27, 2020 10:45 pm Still trying to get one from Garmin UK.
If you are losing power at the mount, have you checked the pins on the power lead? People are reporting issues losing them or them becoming damaged.
Garmin are replacing some early mounts, as they were giving a loose fit to the main unit - not as a result of power loss problems.
axamax
Has liked: 7 times
Post by axamax »
simoncrewe wrote: Thu May 28, 2020 2:35 pm
I'll have a check when I get time. The unit also moves slightly in the mount. I don't know why they have the cable separate from the mount. I did manage to get a video of the problem to send to Garmin. It's frustrating not being able to TALK to someone.
axamax
Has liked: 7 times
Post by axamax »
Finally got to TALK to someone at Garmin today. At last they are sending me a replacement mount. I'm mhoping this will sort the issue. I asked whether the cable requires replacing at the same time they reckoned No. We'll see what happens when it arrives.
Has liked: 375 times
Been liked: 383 times
What was your problem talking to them? Did you call the freephone number 0808 238 0000 or the standard 03708 501242?
axamax
Has liked: 7 times
Post by axamax »
02380524000 was the number I had. Tried the freephone number yesterday and got through.
The support team had stopped responding to my emails on the 27th may.
Not sure where that number came from, the two I posted are the official Garmin ones. Glad you got it resolved though.
axamax
Has liked: 7 times
Post by axamax »
Turns out the order was raised on the old part number, hence not sent out.
Then an order was raised that required me to pay postage. (£5.99). So another phone call and an order was raised without the postage. 24 hours later it still isn't showing as shipped.
axamax
Has liked: 7 times
Post by axamax »
Finally recieved the replacement mount 44 days after the original email. Mind you I was lucky to get it at all, it was sent via UPS.
