12 volt accessory plug - need some parts for my Zumo 550 cord
davem37
Post by davem37 »
I need to replace a few parts on the 12 V accessory plug adapter on my Zumo 550 cord.
The following parts were lost by a person who used my Zumo:
- the metal 'tip' of the plug
- the nut that threads into the adapter (holds the tip)
- the spring
- the fuse (easy enough to find)
I'd like to simply replace these parts, but I cant locate them. I've noticed that other charger cords seem to have a slightly different diameter (11/32 ?) than the Garmin unit (3/8).
Any suggestions ?
dave726
Has liked: 5 times
Re: 12 volt accessory plug - need some parts for my Zumo 550 cord
Post by dave726 »
First suggestion that comes to mind is to not let someone else use your 550. :)
You can get a replacement 12v accessory plug, take the old Garmin one apart and remove the wires (or just clip them close to the plug, strip the wires and install the replacement plug. Most have screw terminals so no soldiering required.
davem37
Post by davem37 »
dave726 wrote: 29 May 2018 14:47 First suggestion that comes to mind is to not let someone else use your 550. :)
It was my wife who borrowed it while renting a car !!!!!!!!!!
I thought about just buying a accessory plug and splicing it in, replacing the existing plug. I'm not sure if the plugs I looked at could be taken apart/support a solder-less solution. Who carries such a plug ? How do I ensure that I keep the correct +/- polarity ? I assume the 'tip' is the + ?
kioolt
Post by kioolt »
Before you buy a standard plug you need to make sure that there is no voltage regulator in the original plug. I don't know if the Zumo is actually 12 volts. It may have a voltage reducing circuit built into the accessory plug.
kioolt
Post by kioolt »
I just did a quick check on Amazon. You can buy a new 12 volt accessory cord for your Zumo 550 for about $10 and be sure it is the right one.
kernowing
Has liked: 134 times
Been liked: 61 times
Post by kernowing »
The 550 runs on 4.2 volts so your supply needs to be reduced.
2007 GL1800 Goldwing
Zumo 660LM
davem37
Post by davem37 »
kioolt wrote: 30 May 2018 01:36 I just did a quick check on Amazon. You can buy a new 12 volt accessory cord for your Zumo 550 for about $10 and be sure it is the right one.
I had done some checking on Amazon and eBay, but could not find anything OEM for under $20.
If I limit my search to 4.2v, I suspect that eliminates most of the non-OEM.
Please post or PM a link to the cord.
dave726
Has liked: 5 times
Post by dave726 »
kernowing wrote: 30 May 2018 07:04 The 550 runs on 4.2 volts so your supply needs to be reduced.
Doesn't the cradle have the voltage reduction electronics?
kernowing
Post by kernowing »
dave726 wrote: 30 May 2018 16:36
I'm not really sure on that Dave, just know that a mate plugged his Nuvi into an accessory socket on his bike and it sort of went fizzzzzz and stopped working :shock: A small wisp of smoke was seen to rise from the Nuvi :roll:
Zumo 660LM
kioolt
Post by kioolt »
Why does it have to be OEM? I'd just buy one that is for the 550.
https://www.amazon.com/s/ref=nb_sb_noss ... ower+cable
