Report Safety Camera button
Today I went past a speed camera but my Zumo XT2 gave no alert for it, so it was not in the camera database. Luckily I noticed the camera and the lines marked on the road and I wasn't speeding, but this got me thinking there should be a simple way to report missing cameras. It would be good if there was a button on screen which I could just touch.
When I got home I looked at the XT2 and found a "Report Safety Camera" item mentioned in a menu but it's greyed out, as are some other items.
How I found it.. From the main map screen, press the 3 bar menu at bottom right of the screen which goes to a screen showing 13 items but many of these are greyed out and cannot be selected.
The greyed out items are:- Report Safety Camera, Towns Ahead, Group Ride, Elevation, Turns, Zumo R1 Radar
The available options which are not greyed out are:- Track Recorder, Traffic, Up Ahead, Trip Data, Music Player, Weather, Phone
Anyone know why some items are greyed out and unavailable and/or how to enable the option I want?
My XT2 is connected to the Tread app on my iPhone and my cardo headset.
BTW, in the "Up Ahead" settings I came across "Garmin Red Light Cameras" but this wouldn't let me put a cross in the box to select it.
So does anyone know if it's even possible to have Report Safety Camera option?
Re: Report Safety Camera button
No, I cannot find it either.
I think it used to be there. It is there on the XT1 but is greyed out. It isn't there at all on my XT2.
Elevation, Turns are all available if there is a route active. (Even under simulation)
Zumo R1 Radar, Group Ride, Towns Ahead are grey. But I don't have a R1 Radar. You can set up a group ride without a Group ride radio. It uses your phone data . Perhaps people need to have joined it to be able to see anything. Towns - maybe it hasn't come across anywhere ahead yet. Im at home at my desk.
Report safety camera is not there now. v5.40 system software on the XT2
It is there but greyed out on the XT1.
I forgot all about trying with a route planned, so just tried it. Report Safety Cameras is still greyed out. Group ride and R1 radar also greyed out, neither of which I use anyway.
Strange how Garmin makes features disappear or stop working with newer (improved/updated) devices and/or software.
The remainder of Group ride works - ie I can set up a Grop Ride and invite people.
I understood (but don't know) that their position just appears on the map.
Maybe the Group ride feature that is greyed out is for the GroupRide Radio facility ?
It's worse than I initially thought. I've discovered after a ride out today that none of the speed camera alerts are working at all. I usually let it update over wi-fi but I'm going to plug it into the computer and see if anything updates from there.
It would be really good if it also gave warnings of blocked roads/standstill traffic by colouring the road red or something, like google maps and apple maps (plus most others) do. I've lost track of how many roads I've been stuck in today with dozens and dozens of cars bumper to bumper, going nowhere. The roads are too narrow to pass the cars, with parked cars either side and cars/trucks trying to get through in both directions. It seems everyone was out today enjoying the sun.
I'll see what happens when I plug into the computer, but I don't hold too much hope. After various different Garmin devices, I'm losing faith in them. Specially when I meet people using cheap Chinese apple car play style devices which just work, are very easy to use and do everything no problem at all.
Speed camera alerts have to be turned on and you have to have downloaded the latest cyclopse updates using Garmin Express.
Safety cameras are in Settings ->Driver Assistance->Proximity Alerts->Alerts / Type of Alerts ->Garmin Red Light Cameras
and for Audio -> set the alert near proximity points.
I often see a message to indicate that Speed and Red Light cameras can now be displayed in the list of "up ahead places" which can be shown in the right hand pane. But the cameras just show up as I am riding. I don't take much notice as I'm never over the speed limit anyway.
There used to be a way of getting three small icons on the right of the screen if no other window was displayed - I used to have Skip showing . I can't remember how to get those there now. ... Found it. Show the map. 3 bar menu bottom right. Spanner, top left. Nothing there to helpt though now. Lots of other stuff though.
The XT2 looks ahead for traffic information - but it seems to be only as far as the next Via Point.
So if you have routes with lots of Via Points rather than shaping points - it isn't going to spot many roadworks up ahead.
You have to have the traffic turned on - in a few places.
i)Settings->Driver Assistance and then - Speeding Alert / Reduced Speed Tone / Proximity Alerts
ii)Settings->Map Display->Map Layers->Traffic also Up Ahead Places is an option for red light cameras.
But you can use the Zumo map to browse for traffic and road closures, and you can get a display on the right hand side of the screen showing traffic issues ahead on your route.
The roads are colour coded to show where there are delays - but only at certain zoom levels.
Take a look here. These were obtained on the Zumo XT, but I have just checked and managed to get very similar displays, using very similar option on the XT2.
You have to wait quite a while for it to collect this amount of data, so give it a few minutes. On the road, I find that if you have displayed the traffic info at the right hand side and it says no-delays, then that isn't updated as quickly. If you close the view down and then open it up again, it seems to force a refresh. That's not an issue - becasue it might take you 20 minutes to reach particular traffic problems, and it will have updated easily in that amount of time.
I've attached a couple of screen shots, but the link has explanations and many more screen shots.
https://www.zumouserforums.co.uk/app.php/ZXT-P54a
- 2156017.png (131.11 KiB) Viewed 2250 times
- 2133494.png (457.18 KiB) Viewed 2250 times
- 940193.png (801.79 KiB) Viewed 2250 times
You mentioned the latest Cyclops updates have to be downloaded using Garmin Express.
I already had cyclops installed and working perfectly with both sound and visual notifications. I wasn’t aware Cyclops only updated via garmin express, not over wifi, so I may not have the latest database, but most fixed cameras don’t move
The strange thing is, after working great for months it’s just stopped working. Speed cameras (and average speed cams) were always shown on the map in their location and as I approached, a banner at top of the screen would even advise the distance to the camera, counting down until I reached it.
It’s not as though I’m some kind of speeding tearaway, I just like having the comfort of knowing where the cameras are just in case.
As I mentioned, my XT2 auto updates over wifi; I’m wondering if it may have updated and changed something whilst powered up in the garage connected to wifi.
Regarding traffic, I get a message on right side of screen mentioning delays on route etc, but I’ve never noticed the road colour changing to red on the map screen.
You mentioned that having lots of via points or shaping points on a route can cause it not to spot roadworks up ahead. I actually don’t have any routes saved and have never used via points or shaping. I only have locations saved as waypoints. So if/when I want to go to a saved waypoint, I select it as the destination and let zumo work out the best way to go. I only use one waypoint at a time. BTW, I find it also doesn’t make any difference what the garmin adventurous routing slider is set to.
Tonight I connected the XT2 to the computer and reinstalled cyclops via garmin express. Tomorrow I’ll check my settings using the info you posted as a guide and see how it goes.
Thank you for the help and for going to the trouble of posting screenshots, much appreciated.
I have found the feature to report a safety camera on the Zumo XT1.
It is in the set of options that is displayed when you select the 3 bar menu in the bottom right corner of the map screen. When you select that a side window appears which shows three option - My Direction, Oncoming, Remove
The side window disappears after a few seconds. So it wasn't just a simple single button press that was there all of the time.
Since my XT2 is in a state where I need to reset it anyway (I have Tread synching), I've just rolled back the software to a previous version - 4.80.
Safety cameras wasn't on there either.
I don't know when it might have disappeared
It's all very strange..
With everything setup how you said, it's still not showing speed cameras on the map or making any sounds or showing any warnings when approaching them or anything! I even went through an area with average speed cameras every half mile or so, again nothing!
When approaching a different speed limit area the alert appears at the top of the screen and it sounds the bonging tone. So it's intelligent enough to know when the speed limits change, but too stupid to show speed cameras.
Also, I changed Driver Assistance > Proximity Alerts > Audio, from single tone to continuous tone, but this made no difference at all.
TBH, I'm now reaching the point of giving up with it altogether and parting ways with Garmin. Things should not just disappear and/or randomly stop working. I don't even know what else isn't working and can't really trust it. For the cost of these things, they should be reliable and work perfectly. It's very annoying that cheap Chinese Carplay devices just seem to work and are easy to use.
Garmin seriously need to get their act together but I suspect there's little chance of that happening.
Thanks again for your assistance.
Ive just been replying to another thread....about waypoints on the map....
Try turning on 'Up Ahead Places' within the map layers area.
It will show all sorts of other icons, but if that reveals the speed cameras, other stuff can be tuned out by adding your own search categories to display .
I don't know if whether this solves the camera issue, but it is worth a try.
