New to Zumo XT. Can I display more than one track on my screen? On my GPSMAP 60, there is a page to check or uncheck tracks to display on map.
I often lay out a ride that's possibly going to take too long, and put in short cuts (separate tracks, with different colors ) to bail out early. I'll often have 3 or 4 active tracks displayed, and can use any one of them to quit early.
I can't figure out how to select more than a single track from the menu on my Zumo XT. Thanks
Displaying more that one track
- Has liked: 2 times
- Been liked: 1 time
- lkraus
- Has liked: 69 times
- Been liked: 189 times
Re: Displaying more that one track
If you have activated Explore, the combination of tracks you want to display need to be added to a Collection, and then can you choose to display that Collection. A track can be a part of multiple Collections.
If you have not activated Explore (or chose to break the connection to Explore) you can toggle the display of each track from the Tracks app. Select the track, tap the wrench icon, check the box to "Show on Map".
Thank you. Very helpful. I would have never figured this out alone. Just finished breaking from Explore and I can do as you indicated
