Navigating with a Zumo - Useful Info - Booklet to Download
I have attached a document that I wrote last year for a presentation that I gave for a motorcycle tour company. I had it professionally printed so that they all had something to go home with. Not specifically about the XT, but all applicable to it.
I thought that it was about time that it saw the light of day on this forum.
A5 Nav.jpg (154.15 KiB) Viewed 10233 times
The- attached files are the same - except - v1-2 has two pages side by side. For a wide screen.
v1-1 has single pages - best for viewing on an ipad in portrait mode.
Navigating with a Zumo v1-2.pdf
(1.56 MiB) Downloaded 1018 times
Navigating with a Zumo v1-1.pdf
(1.56 MiB) Downloaded 997 times
Some Videos elsewhere on this site which relate to the use of the Zumo XT1
Links are to the post in which these appear.
  1. Flying a Track in Google Earth : Video and How to pdf file.
  2. Missing a Shaping Point ? : Two videos showing different behaviour when going off route. a) With a 'Saved' Route, b) With an 'Imported' route.
  3. Mising a Via Point ? : Two videos showing different behaviour when ignoring a Via Point a) With a 'Saved' Route, b) With an 'Imported' route.
  4. Fixing the RUT Issue : One way to Make your 'Imported' route behave like a 'Saved' route.
  5. Set Up Garmin Drive : How to set up your phone and XT with Garmin Drive (and Explore if you wish).
As an explanation of Saved versus Imported, jfheath wrote: The Zumo XT separated its routes into two categories: In the Trip Planner App routes are listed under two headings - 'Saved Trips' and 'Imported Trips'. Saved trips were those originally created using the XT1 Trip Planner App. Imported trips tended to be the ones created using route planning software and sent to the XT as a Gpx file and then imported.
The two kinds of routes behaved differently in my tests if the XT had recalculated the route - eg after pressing Skip:
  • Saved Trips seemed to be reliable in calculating a new route to the next routing point if you had to stray from the plotted line.
  • Imported trips seem to head for the closest point of the route if you deviate. If that point is behind you, you seem to end up always being directed back the way that you came. Even if the next routing points is just a couple of miles in the direction that you are heading.
Getting the XT to treat an 'Imported' trip as a 'Saved' trip seems to have the effect of altering the behaviour when you are forced to deviate from the plotted route.
Scarecrow
Been liked: 28 times
Re: Navigating with a Zumo - Booklet
Post by Scarecrow »
What a good Job
Well done that Man
Has liked: 203 times
Been liked: 286 times
Brings back a lot of memories John. Especially why I do the things the way I do them with the XT. Nice to have the final version in PDF.
Rofor
Been liked: 83 times
Austria
Re: Navigating with a Zumo - Useful Info - Booklet to Download
Post by Rofor »
Many thanks for that, John!
Bye, Robert :)
Mzokk
Has liked: 63 times
Been liked: 35 times
Post by Mzokk »
Brilliant John you certainly put a lot of work into this. Much appreciated.
ZFtracker
Has liked: 22 times
Been liked: 39 times
Post by ZFtracker »
Thank you.
Zumo 590
Montana 610
Drive 60
inReach Mini
simoncrewe
Has liked: 47 times
Been liked: 38 times
Post by simoncrewe »
Many thanks - as usual brilliant information on your part
finerone
Post by finerone »
Thank you, that was very helpful.
federico
Italy
Post by federico »
Thank you, brings clarity...
Steve M
Post by Steve M »
Thank you.
Now to put into practice some of the help you supplied. Much appreciated. 🙏
