XT coming next week
twowheelstom
Has liked: 146 times
Been liked: 54 times
Re: XT coming next week
Post by twowheelstom »
lkraus wrote: Fri Feb 02, 2024 11:00 pm I recommend finding a way to tap into switched power on the bike. There is probably some circuit that can handle the additional 0.6 amp without blowing a fuse. If in doubt, use a switched circuit to trigger a relay powered by the battery. AND actually shut down the XT if it will be unused for a few days.
for a switched circuit, some will connect a relay to bike's rear tail light circuit because that tail light circuit is key on/off switched, then from bike battery to relay then relay to Zumo cable
Zumo 396
1994 Yamaha 250
twowheelstom
rbentnail wrote: Sat Feb 03, 2024 11:37 am (I have a 6+ gallon tank).
my kawasaki tank is 15 litres, i begin to panic for a gas station when I've gone hour and quarter riding, I can't go far lol
Zumo 396
1994 Yamaha 250
Somewhere midway through this discussion @danham posted about the Silicone Sling by Tackform as a method of securing the XT in place. Well, I received mine this morning and had one installed within 5 minutes. I am really impressed. I think he exaggerated when it said "The extra 2 seconds required to hook them up..." though. I takes me 3 seconds. :D I didn't try it with gloves on though.
Thanks again @danham.
Tackform Sling2.png (388.57 KiB) Viewed 1398 times
twowheelstom
excuse my ignorance, I'm a newbie so allowed lol, but what's a silicone sling? and where did you get it? is there a website for that item, I assume it's to secure the XT to the cradle better, will I need one of those?
Zumo 396
1994 Yamaha 250
twowheelstom
I did a little google digging and found this, is this it?
https://www.tackform.com/products/pack- ... ings-black
Zumo 396
1994 Yamaha 250
twowheelstom wrote: Sat Feb 03, 2024 4:24 pm I did a little google digging and found this, is this it?
Yes.
twowheelstom
could you show another picture of the sling but of the back of the cradle? will the sling wrap around the mount cable?
Zumo 396
1994 Yamaha 250
twowheelstom wrote: Sat Feb 03, 2024 4:33 pm could you show another picture of the sling but of the back of the cradle? will the sling wrap around the mount cable?
You disconnect the cradle at the ball clamp, slip the sling over the ball, then reassemble. The sling then stays in place ready for its four corners to be stretched around the corners of XT.
Tackform Sling3.png (244.14 KiB) Viewed 1391 times
twowheelstom
pardon my idiot question, but by removing the cradle at the ball clamp to install the sling, doesn't that mean to also remove the cradle from ball again again when wanting to take the XT off the cradle?
Zumo 396
1994 Yamaha 250
The sling is just an oddly shaped rubber band. You clip the XT into the cradle and then stretch the corners of the sling over the corners of the XT. To remove the XT you slip the corners of the sling off the corners of the XT and then release the XT from the cradle. The sling remains in place between the ball mount and the cradle.
