Sounds like a problem with the pins not making contact properly to me.
Connecting via the USB port goes straight into unit socket and doesn't use the pins - this works ok.
You know you have voltage across the pins but the power doesn't reach the Zumo - so likely the pins aren't connecting properly I would guess.
3D AM Adapter
- Site Admin
- Has liked: 437 times
- Been liked: 264 times
Re: 3D AM Adapter
I'm not so sure as the zumo is turning on when the bike is powered uppurds wrote: Tue May 09, 2023 4:19 pm Sounds like a problem with the pins not making contact properly to me.
When I was having issues it was the charge controller not putting enough voltage out but @Don has replaced that
One thing I did notice on mine though is when it stopped charging if I turned the screen brightness down it would start to charge again
Have you also tried to start the bike then fit the zumo? as on BMW bike there is a short interruption of the power on all auxiliaries when you hit the starter
Re: 3D AM Adapter
Good pointStu wrote: Tue May 09, 2023 6:58 pmI'm not so sure as the zumo is turning on when the bike is powered uppurds wrote: Tue May 09, 2023 4:19 pm Sounds like a problem with the pins not making contact properly to me.
- Site Admin
Re: 3D AM Adapter
Don't write it off though as it might just be enough to turn it on and not charge itpurds wrote: Tue May 09, 2023 7:12 pm
Re: 3D AM Adapter
Thanks Purds and Stu, I will persevere with the unit and try what you suggest and hopefully the unit will start charging. Kind Regards to you both for your help.
