Hi All,
Is there a way to adjust brightness other than Settings > Display > Brightness?
TIA
Is there an easy way to adjust brightness?
- lkraus
- Has liked: 87 times
- Been liked: 248 times
Re: Is there an easy way to adjust brightness?
There is no other way that I can find. I usually set it at 100% for day use anyway. It would be nice if it would save a separate level for night mode, when 50-60% is sufficient.
I run mine at 100% on the bike too but that is too bright when I am messing with it in the house. One button access to the brightness slider would be nice, similar to how Volume adjustment works.
