as earlier post I had to revert to earlier GE
I've tried it on my second PC and it still wont load maps to PC with GE 7.13.1 for some reason
CN EU 2023.10 NTU
Re: CN EU 2023.10 NTU
If you have older versions of the maps on a laptop or PC then Basecamp can install maps from this dataset. You just select the map version and the tiles to upload. Hold the mouse button down and drag the cursor to select multiple tiles. Right click to unselect a tile. It takes ages but I have UK, France & Spain back on my device from the 2022.22 maps. I had over half of the internal memory available, so sufficient. If you lack space then I assume you can use an SD card.
- Site Admin
- Has liked: 398 times
- Been liked: 212 times
- Has liked: 3 times
- Been liked: 19 times
Sorry Sussamb
I'm not That computer literate
but HOW do I delete the downloaded map data
It will show as an installed programme in Windows settings. Go to "Add/Remove" programme in settings. Simply type "add/remove" in the search box at the bottom left of your screen and follow the instructions
