Strange boot problem
Posted: Tue May 26, 2020 5:18 pm
Sometimes will the Zumo 590LM not boot up, when the motorcycle ignition is on.
This not help to remove it from the cradle and try to press on the main switch behind the unit.
This is completely dead with black screen.
Only way to wake up the unit, is to remove the internal battery for few seconds.
This happen (in average) every 5 times. eg. 5 times with ignition om, the unit boot perfectly up. the 6th is dead.
The unit is updated with the latest updates and maps from Garmin (Garmin Express ver. 6.21.0.0)
Are this boot issue a known problem?
