There is some issues with Google maps! They have changed their API terms and put priced a lot of people! As a result Google maps no longer works with ITN converter and a whole host of services!CollingsBob wrote: ↑23 Jan 2020 18:14Can ITN converter be used to convert a route created in Garmin Basecamp to Google maps?... I installed it but it wont import a .gdb file..Stu wrote: ↑22 Jan 2020 13:29 Anyone tried ITN converter? http://www.benichou-software.com/index. ... =3&lang=en
I used it when I had a tom tom
I found the maps smoother than basecamp and adding waypoints to for the route just makes them shaping points but you still have to import it to basecamp to check which isn't a problem
Basecamp a bit clunky
- Site Admin
- Has liked: 424 times
- Been liked: 241 times
Re: Basecamp a bit clunky
I'm running version 4.7.1. I've found a link to download the older version, you suggesting I should download and use that if I want to use it in conjunction with Google Maps?
Yes. The 4.6.2 works with google earth.
- Has liked: 144 times
- Been liked: 21 times
https://www.technoleros.com/download/ga ... amp-4-6-2/
