Page 3 of 3
Re: It might be me
Posted: Sun Nov 18, 2018 2:43 pm
by JimKat2
advnzer wrote: ↑Sat Nov 17, 2018 10:07 pm
just check that the folder structure on the card is EXACTLY the same as the device.I didnt hink there was a routes folder????
Yep the path was the same. it was route.gpx file at the end. So I'm happy about that.
Now then. Does anyone know what is going on here?
I have re-installed Garmin Express and still get the same error. Also I am on a different network to my home. I think this error is why I have no maps tab
Which in turn prevents me from (Re-) installing the latest map to Zumo & BC. At the moment BC is using the Zumo for it's source map when connected, or Global Map when not connected to Zumo.
- GE01.png (185.08 KiB) Viewed 2931 times
Cheers
Jim
Re: It might be me
Posted: Sun Nov 18, 2018 7:14 pm
by sussamb
Different network to your home? Exactly what do you mean by that? If it's a network at work it's probably not configured to allow you to do what you want.
Re: It might be me
Posted: Mon Nov 19, 2018 1:56 pm
by rbentnail
sussamb wrote: ↑Sun Nov 18, 2018 7:14 pm
That's my thought too. Downloading stuff at work is a big no-go for me.
Re: It might be me
Posted: Mon Nov 19, 2018 5:46 pm
by JimKat2
rbentnail wrote: ↑Mon Nov 19, 2018 1:56 pm
I would tend to agree with you if I was on the company network. We are now prevented from using USB drives and installing s/w that is not IT approved.
A Zumo would be flagged up as a usb drive and blocked.
However we have a Corporate Guest WiFi network that is more open (to within acceptable limits) and it is this one that my laptop is connected to and I still have the same results.
I have another couple of avenues that I need to explore so I will let you know how I get on.
Re: It might be me
Posted: Tue Nov 20, 2018 2:56 pm
by rbentnail
JimKat2 wrote: ↑Mon Nov 19, 2018 5:46 pm
Ah, I see. I work for a big corporation that supplies Guest WiFi, they make it clear that many of the same restrictions apply to it as does the internal network. And I found it does- even my phone slows to a crawl with their WiFi- so I've pretty much given up using it. Maybe your situation is the same.
Re: It might be me
Posted: Tue Nov 27, 2018 3:56 pm
by JimKat2
Well I have tried all the fixes to resolve the issue with updating maps onto Basecamp. But am no further forward.
Uninstalled,re-install GE and BC.
I have switched off as much internet security on my home network as I am prepared to do and connected directly to my router with a patch cable so no WiFi restrictions. Run a speed test and got 16/2mbs.
So I think I shall have to go as I am, until the next map update and then see what happens.
I can create routes and load them onto the Zumo so can do my pre-planning, it's just some of the expected functionality that is missing.
Thanks for the support folks.
Ride Safe
