No more updates?? What will replace BC?
Posted: Tue Mar 28, 2023 11:19 pm
by Exrm193
So Garmin are no longer updating BC??
What will they replace it with??
Re: No more updates?? What will replace BC?
Posted: Tue Mar 28, 2023 11:35 pm
by Peobody
They are pushing Garmin Explore. Here is an overview webpage:
https://support.garmin.com/en-US/?faq=P ... XEb3czosX6
Read lots of posts about it before you jump onboard because there are a good number of folks who are not fans of it. Basecamp may no longer be under development but it still works. I will be sticking with it until it doesn't.
Posted: Wed Mar 29, 2023 9:57 am
by Les
Exrm193 wrote: Tue Mar 28, 2023 11:19 pm
I've been using Mapsource for at least 15 years, just my opinion of course, but it doesn't need 'updating' it works perfectly (for me) just as it is.
I use it with my Zumo 660, my Camper 760 , and my wifes Drive 40, with excellent results.
I do use Basecamp occasionally, mainly to recalculate a batch of routes all at once, something Mapsource can't do... but generally find Basecamp far to 'fussy'.
Posted: Wed Mar 29, 2023 12:02 pm
by rbentnail
I too will stick with Base Camp as long as it functions. I remember all the predictions of demise of Mapsource too. None of it matters.
I found the transition from Mapsource to Base Camp to be easy and painless but I understand how it is with others. I couldn't figure out Tyre either
Posted: Sat Apr 01, 2023 3:13 am
by Daibach
Garmin says Explore is not designed for Zumo XT.
Posted: Sat Apr 01, 2023 1:52 pm
by Peobody
Daibach wrote: Sat Apr 01, 2023 3:13 am
Interesting! This is a quote from an email I received from Garmin Product Support when I inquired into a route recalc issue:
"I understand you are using BaseCamp to import routes. An alternative option that provides a much better end user experience is using the Garmin Explore app. Here is more information on using Garmin Explore: ..."
I consider that a strong nudge towards Explore over BaseCamp.
Posted: Sat Apr 01, 2023 2:54 pm
by sussamb
Says the App isn't designed for it
https://support.garmin.com/en-GB/?faq=o ... wZzO1ME7z9
Explore does work with the XT
https://explore.garmin.com/Account/GarminUser
Posted: Sat Apr 01, 2023 3:21 pm
by Peobody
I am very surprised that Garmin support directed me to use the app with my XT when it clearly is not supported. Obviously they need to do a much better job of differentiating between usage of the Garmin Explore website and the Garmin Explore app. I do not have any experience with either nor do I care to pursue Explore as long as Basecamp is doing everything I need it to do.
Posted: Sat Feb 01, 2025 2:00 am
by epv
Old thread, but I'm new to Basecamp and frustrated that it crashes so much on Mac. I've been trying the Explore site but as far as I can tell all it allows you to do is select a few points and send them to a device to be routed, which isn't much use if you want to be specific about which roads to take. MRA seems better but I haven't figured out the intricacies of exporting correctly for Zumo or Montana. It seems to make a route with only the start and end points, and a track with all the shaping points, but no way to combine them into what Zumo calls a "trip."
