That's almost correct @Peobody - and no, the more people that pass on good advice, the better.
Waypoints - be careful here. Waypoint are the points that you create in BAsecamp using the Waypoint Flag tool. They are saved in the collection of Zumo 'Favourites (UK) or in Zumo 'Saved' locations. Waypoints can be put into a route once they have been created and they can be made as either Shaping Points or Via Points.
It is easy to confuse the term Waypoint with the term Via Point, becasue when you place them into a route in Basecamp, it places them as a Via Point.
Via Points alert on arrrival and show up on the Zumo screen as an ornage flag. Shaping points do not alert on arrival, and show up on the Zumo screen as a blue disc.
If you miss a Via point, the satnav will always try to get you to go back to it. Always. The only way to escape from this is to press 'Skip', it will then calculate a route from where you are to the next route point (via or shaping). (BUT as
@Peobody said, it will also calculate the entire route - it will still visit every route point, but it may choose different roads fromt he ones that were plotted originally.
If you miss a Shaping Point - exactly the same thing happens. The satnav calculates a new route from where you are now, to the same shaping point that it was trying to get you to. But unlike a Via Point, if you eventually rejoin the plotted route AFTER the missed point, the satnav will stop trying to navigate you back to the missed point, and will simply continue navigating ahead.
Lesson - Use Via Points for places that are key landmarks - places that you know that you will defintitely pass through - and make sure that they are placed accurately. Use shaping points for the rest of the route. I just use Via points to mark the road that I want to be on after a coffee stop - a point that I will pass through whether I stop for coffee or not.
You say that the XT recalculates the entire route if you miss a shaping point. I don't think that it does, but now that you have said it, I will double check as it was one of the first things that I tested 2 years ago - so it may have changed (or I may have made a mistake).
If you go off route - yes, the satnav recalculates a route, but I think that it is only up to the next route point. Not beyond that.
Here's an example:
- bypass coffee.jpg (15.61 KiB) Viewed 1855 times
I have a route plotted on the Magenta Line. There is a shaping point called Coffee Stop. There is a Via Point at Point D. The yellow road from a to B to C is a bypass that avoids the village in which the coffee stop is situated. B is a point somehwere about mid-way between A and C. C is not a route point at all, it is the place where the original route meets the bypass. I am assuming that the satnav allows me to perform a U turn.
I am approaching from the left of the image. At A, I decide that I don't want to stop for coffee, so I head down the bypass towards B.
As soon as I do this, the satnav will recalculate the route, trying to get me to visit the next route point in its list - the shaping point at Coffee Stop.
Perform a U turn, I ignore it and continue
Perform a U turn ... ditto
At around point B, the satnav stops asking me to perform a U turn and instead draws a magenta line on the road ahead towards point C
As I approach C the satnav springs into life again and tells me
In 1/4 of a mile, turn left at junction It is still trying to get me to the coffee stop shaping point (I haven't visited that point yet, and it is the next point in the satnav's list).
As I reach C, I do not turn left, and continue ahead. I am now on the magenta line which is plotted from the Coffee Stop Shaping point to the 'After Coffee Stop' Via Point at D. Because I am on the route and I have not missed out any Via points, the satnav continues navigating me to the next route point. The Via Point at D.
Arriving at After Coffee Stop on the left.
Had the Coffee stop been a
Via Point, it would have kept insisting that I go back to it. Even though I am on the magenta line going towards D, and would still continue trying to get me to go to the Coffee Stop even after passing D.
