map too big for Zumo? how to install on SD card
hammer
Re: map too big for Zumo? how to install on SD card
Post by hammer »
As already posted, the "solution" doesn't work for me. When trying to use mapinstall (which is also how basecamp installs maps) I get maps locked notice eventhough maps are unlocked in basecamp.
93aspy
Post by 93aspy »
carolinarider09 wrote: 16 Jun 2021 13:11 I am not at a place where I can look up what I use to do to make this work on my 665. But I did send my 665 off to the Palm DR and got a 16GB chip installed and the issue no longer exists. Well worth the money and removes the issue of map file size.
Again, not an immediate help for you but just one more option.
I second that. Send your unit to Chris Short at Shorttronics AKA Palm Doctor. There are 2 options available. An 8 gig or 16 gig memory upgrade. I did the 16 gig and the entire north American mapset is installed on my 665. I have used Chris for a few repairs now. He is fast, courteous, and knowledgeable. You can't go wrong sending your unit to him...
https://www.palmdr.com
Les.
NeilP
Post by NeilP »
Zumo 660.Latest and last NT Europe 2025.10
This thread did give me the solution.
Still cant get the entire region, since the 2025.10 map is 6Gb and limit seems to be 4 Gb due I guess FAT32
I was insitially confused aboutthe instructions to use BaseCamp to sned the map as it does not give that optoion directly
Seem you need to chose at least one waipoint to brign up the Send to Device Window, and then use the "Send Maps" option that then launches Map Instal AND IT IS MAP INSTALL that offers to send the map to SD card.
That has taken over a year to work this out...
or actually remember it as I had done it in the past
So for myself or other in future.this is reminder pn how to do it
Open BaseCamp
Send a Waypoint
Choose to Send maps to device
then select the SD card and Options and select the areas you need.
Has liked: 361 times
Been liked: 375 times
I've never needed to send a waypoint prior to sending a map. If it works for you though ... :D
NeilP
Post by NeilP »
Maybe if I go in just with map Install and not via baseCamp it may work with not waypoint
