Page 1 of 2
Basecamp Startup Error
Posted: Sat Mar 20, 2021 3:51 pm
by VA3TWT
Good day;
I get the following error when I start Basecamp (latest version):
"There was a problem communicating with the Zumo XT
An error occured while reading the following file(s):
gpx/current.gpx"
Anybody know what I did wrong and/or how to correct this error?
Thanks for any and all help;
Gord
Re: Basecamp Startup Error
Posted: Sat Mar 20, 2021 7:12 pm
by sussamb
Did I answer this elsewhere? Anyway the solution is just delete the file
Posted: Sat Mar 20, 2021 8:45 pm
by VA3TWT
Any hint as to where the file is that needs to be deleted? I don't see a gpx folder or current.gpx file. Using Windows 10.
Posted: Sat Mar 20, 2021 10:07 pm
by sussamb
It's in the GPX folder on your Zumo
Posted: Sat Mar 20, 2021 10:47 pm
by mzeist
on my windows 10 its in: This PC\zūmo XT\Internal Storage\GPX
Posted: Wed Mar 31, 2021 10:17 am
by ondras76
I have the same problem and the solution with delete the GPX file in Zumo doesn't help :(
Posted: Wed Mar 31, 2021 8:38 pm
by rbentnail
I've always had better luck with the 595 by having the computer do one thing at a time. I open BaseCamp and wait. It's a slow process. After a few minutes I plug my device in and wait again. It's an even slower process this time. Sometimes it can take upwards of 6 to 8 minutes for everything to work correctly.
Posted: Thu Apr 01, 2021 4:29 pm
by ondras76
Thank you, but still the same. Crash after the Zumo is connected. :(
Posted: Tue Apr 13, 2021 6:39 pm
by ondras76
so i found a solution. Helped to delete POI directory in ZumoXT.
Posted: Thu Apr 15, 2021 9:53 pm
by Stu
I am also getting this error and have tried the suggestions here but nothing seems to work!
