Page 2 of 2
Re: Checking for update
Posted: Tue Aug 29, 2023 8:28 pm
by Peobody
rbentnail wrote: Tue Aug 29, 2023 7:11 pm
Look at Settings/Wireless Networks/WiFi. You untick the box to stop updates.
There is something else involved because mine doesn't check for updates even with wifi enabled and connected. I think that it used to though. I don't know why it doesn't auto-check now.
Posted: Tue Aug 29, 2023 10:28 pm
by PaulaRay
Thanks for the help.... I did so but unfortunately, it still want's to check for updates. Thanks again. Ray
Posted: Tue Aug 29, 2023 10:30 pm
by rbentnail
Peobody wrote: Tue Aug 29, 2023 8:28 pm
Other than turning wifi off, I've never found a way to NOT update when turned off. Curious to know what makes yours different tho it doesn't matter much. I turn wifi on at home to update and back off again when done. I don't want it updating every time I pull in somewhere that has wifi. Can you imagine? Stop in Mickey D's for a quick pit stop, XT updates and now none of your routes work right and you have no idea why.
Posted: Tue Aug 29, 2023 10:31 pm
by PaulaRay
I'm currently on software version 6.50. There is a new update that I haven't done yet. Are you on the latest version or a different version? Thanks. Ray
Posted: Tue Aug 29, 2023 10:34 pm
by PaulaRay
rbentnail wrote: Tue Aug 29, 2023 10:30 pm
That's too funny...... I was at a Mickey D's when this happened. I feel the same way as you.... I always want to manually update everything if possible.
Posted: Tue Aug 29, 2023 11:17 pm
by Peobody
PaulaRay wrote: Tue Aug 29, 2023 10:31 pm
I am on version 6.50. I am not aware of a new version being available.
Posted: Wed Aug 30, 2023 2:55 am
by PaulaRay
Peobody wrote: Tue Aug 29, 2023 11:17 pm
The following is showing up on my XT for updates. I havn't updated yet due to trying to figure out my current problem.... which may not occur again. Other than that, I want to see what and if the latest software version is any good or not.
- https://www.zumouserforums.co.uk/download/file.php?mode=view&id=2219&sid=421a171c45cbb52ae8f0ae7547ca24fa
- Updates.jpg (351.75 KiB) Viewed 1635 times
Posted: Wed Aug 30, 2023 9:32 am
by Rofor
@PaulaRay - This must not be any firmware update (no new firmware than 6.50 at the moment)!
This could be language files, speech files, POIs and so on! All those updates, excluded map files, will be be shown under 'Software' - the only way to get an idea, which files are updated, is to use Garmin Express on an PC/Mac for those updates. There you can click on 'Details' if the Zumo XT is connected and than you can see in detail, what the update is for...
Posted: Wed Aug 30, 2023 12:10 pm
by lkraus
Some of the updates are pretty trivial, like time zone maps for places you've never heard of. Express found a two minute update a few weeks ago, but "Details" provided no information about what was changed. It only said it was "necessary".
The "update at McD's" scenario isn't too likely since most public wifi requires you to agree to their terms of service, and there will be no agreement screen displayed on a Zumo. Even without that requirement, you have to tell the Zumo which wifi networks to use, at least once. It will not connect to any random wifi it happens to detect.
I never want my Zumo to update automatically. I can imagine coming home from an errand the day before a tour and getting an update that changes a map or algorithm, or has a bug, so that all my planning is wasted. As best I can tell, wifi is used only for updates, so mine is always turned off.
Posted: Wed Aug 30, 2023 1:04 pm
by PaulaRay
Just checked Garmins "wonderful app"..... Garmin Express. There are map updates but, totally useless in my world. As for the software update 7.18.0.0 even more useless which carries problems as shown at the following link. This is exactly why I don't want automatic updates for anything....."Especially Garmin." In regards to my OP, I may remove my cradle from switched power to direct. The little bit that I would leave my XT in the cradle, all I need to do is tap the power button for sleep/charge mode and/or power it off.
https://forums.garmin.com/apps-software ... n-7-18-0-0
- Garmin Express Updates.jpg (199.96 KiB) Viewed 1610 times
