I just discovered this forum and found a very interesting post concerning the way to use Zumo XT.
Since 2003, I owned Zumo 500, 550, 590 and the XT since a couple of days.
I use GPS both with motorcycle and car for tourism and panoramic roads, for day life, I use Waze.
I subscribed to this forum to exchange ticks and trips and good ideas .
I'm french (nobody's perfect )
Hello everyone
- Has liked: 96 times
- Been liked: 201 times
Re: Hello everyone
Hello, and welcome to the forum from the southeast of the USA. Hope you find some helpful information and tips you need.
- Has liked: 99 times
- Been liked: 277 times
Re: Hello everyone
Welcome to the forum from another southeastern USAer. This is a great place for learning and sharing. There are lots of knowledgeable and generous folks here that are willing to help out or just talk through ideas you might have that. We'll look to benefit from your knowledge and experience as well.
1995 Kawasaki ZG1000 Concours
- kernowing
- Has liked: 128 times
- Been liked: 55 times
Re: Hello everyone
Welcome to the forum Navi 911. Don't apologise for the French connection, I've always enjoyed my many tours around your wonderful country.
2007 GL1800 Goldwing
Zumo 660LM
Zumo 660LM
- Has liked: 281 times
- Been liked: 613 times
Re: Hello everyone
Welcome @Navi911
The step from the 590 to the XT is not quite as big as the step from the 550 to the 590.
Most of what applies to the 590 also applies to the XT - except that the XT has a couple of serious issues that will catch you out if you are not prepared for them.
1. If you are used to transferring routes from Basecamp, it is the same 2 stage process - transfer by USB and then import. The imported routes can be altered by the XT when fiddling around with the routes on your screen. But you can always delete and re-import the routes if you accidentally change them. Except - if you reconnect your USB cable and transfer more routes, then the previous transfers are over-written. So the tip is to transfer all of the routes that you want on your XT - even if you have previously transferred them before.
2. There are a number of ways of navigating with the XT. Choose the best one for you app.php/ZXT-P45
3. It is a good idea to create a track as well as a route. You may have doen this with the 590. Have both displayed on the map, so if the route is changed as you ride, the track become visible.
4. "Faster time" means head for the faster roads - even if it takes longer ! Create your route accodingly if you don't want to head for the main roads.
5. There is a glitch - quite a serious one - which affects routes that are not created on the XT screen. And we have a fix for it - but Garmin have yet to produce a solution. If the route recalculates when you are riding, and you then deviate from the route for some reason, the XT will forever try to get you to go to the closest point on its new route. This is usually behind you. Solution is either to apply the fix to each route or to not allow recalculations.
This link may be familiar to you - it will certainly make sense if you had a Zumo 590.
Download the pdf. viewtopic.php?t=521
From this document - I have produced a smiliar one on the XT. You can few this on this site in the link that I provided in item 2 above. Click the 'Contents' link at the top of every page.
