Page 3 of 4
Re: 595 Constantly Changing My Route
Posted: Thu Jun 28, 2018 6:08 pm
by rbentnail
sussamb wrote: ↑Thu Jun 28, 2018 4:39 pm
Without the route and seeing what it actually did diagnosing this issue isn't easy. Don't suppose you're able to post the route and explain where it went wrong?
Or is this the same issue as in your other thread, in which case it's resolved?
NOTHING is resolved. Not in this thread, not in the other thread. But I created two different threads for 2 different problems, please do not merge the two. I confuse easily
Again, here's what went wrong:
I preview a route. It matches EXACTLY the route I created using Base Camp. When the route is active, I am following the purple line on the screen. From origin to 1st point all is good. From first point to second point it wants me to take a right then a left into a fenced cow pasture even tho the route I created using Base Camp and transferred EXACTLY to my 595 matched and continued in theory down the same road I was on. And again at the second point to 3rd point, it tried to send me down railroad tracks even tho the previewed EXACT route continued down the same road I was already on. And so on third to fourth point, to fifth, sixth, seventh.....
Describe to me step-by-step how to "post a route" and I'll do it. Skip nothing, abbreviate nothing. I have no idea how to but I will if you think it will help.
Posted: Thu Jun 28, 2018 7:36 pm
by dave726
BC: Select route in lower left pane
Select File>Export>Selection>Select Route Type gdb
Save
Zumo User Forums:This message thread>Reply
Select Attachments Tab below message draft
Select Add files button
Navigate to your Saved gdb file.
Open
Place inline
Submit
Posted: Thu Jun 28, 2018 10:14 pm
by mzeist
how many waypoints (not shaping points) does your route contain?
Posted: Thu Jun 28, 2018 10:17 pm
by kernowing
- GDB.gpx
- (362.86 KiB) Downloaded 276 times
Posted: Thu Jun 28, 2018 10:20 pm
by kernowing
dave726 wrote: ↑Thu Jun 28, 2018 7:36 pm
Save
Open
Place inline
Submit
Yup, that worked for me Dave but it comes up in Mapsource , not BC where the route was drawn?
Edit, It was a cracking ride last week
Posted: Fri Jun 29, 2018 3:01 am
by sussamb
Ah okay. I'm away for a week or so so no chance of looking at this problem, thought it might have occurred because as we discovered in your other thread you were choosing the last waypoint and not the first.
Posted: Fri Jun 29, 2018 5:05 pm
by rbentnail
Save
Navigate to your
Saved gdb file.
Open
Place inline
Submit
The bold section above is a problem. I did the export and save, no problem. When I go to My PC/Documents/etc I can see my exported and saved route.gdb file. But when I click the Attachments Tab/Add Files, it says .gdb files are "not supported".
Posted: Fri Jun 29, 2018 9:42 pm
by Stu
rbentnail wrote: ↑Fri Jun 29, 2018 5:05 pm
Save
Navigate to your
Saved gdb file.
Open
Place inline
Submit
I will sort that when I get chance but at the moment it's bed time
Posted: Sat Jun 30, 2018 4:57 pm
by alan sh
Do you know how to make a zip file from the GDB file? If so, do that and post it. If not, wait for Stu.
Alan
Posted: Sat Jun 30, 2018 6:28 pm
by Stu
Give it a go now and let me know if it works
