Dashboard choices
Posted: Fri Jul 03, 2020 3:38 pm
by Triplog
I'm currently using a Montana 680 but I like the size of the xt screen. Is it possible to have a "clean" map screen on the xt (when not navigating) I.e. with no banners? One of the many advantages of the Montana is the ability to have numerous profiles with as much or little (or no ) information as desired, so the whole screen area can be taken up by the map alone.
Re: Dashboard choices
Posted: Fri Jul 03, 2020 4:51 pm
by simoncrewe
Triplog wrote: Fri Jul 03, 2020 3:38 pm
I have a Montana also & an XT, if you are hoping for a clean map as in the recreation mode, no the XT always has a banner at the top & fields in the corners.
However, as a road going unit the XT is in another league altogether to the Montana. I think the Montana is more rugged & better suited to off road use, which is what I use it for.
The display on the XT and the speed of operation is fantastic. I am finding it a very good unit.
Posted: Fri Jul 03, 2020 5:14 pm
by Triplog
Thanks for the reply and the info. Yes I have to agree that the Montana can be a bit frustrating on road!
As an additional question then do you find the screen area on the xt, with the banners, is more than on the Montana?
Someone did post on a forum a programming "hack" to make the banners transparent (on an older Zumo model) which helped quite a bit - but my brain won't let me recall where or when!!!
Thanks again
Posted: Fri Jul 03, 2020 10:06 pm
by simoncrewe
Triplog wrote: Fri Jul 03, 2020 5:14 pm
Thanks again
Screen size on the XT 120mm X 60mm excluding banner (blocks of text in bottom corners)
Montana 90mm X 50mm
Hope that helps.
Posted: Sat Jul 04, 2020 7:11 am
by Triplog
Yep, that helps!
Thank you.
