Page 5 of 14
Re: WARNING - Garmin Zumo XT hot-shoe connector weakness
Posted: Sun Aug 23, 2020 6:31 pm
by mastercore
I got my replacement cable installed now. Will be much more careful about it on my next off road tour. (starts in 1 week)
Posted: Sun Aug 23, 2020 7:42 pm
by larsras
I have got replacement for both mount and cable and went for a weekend trip. I still loose power connection 20 times / hour. What a piece if sh.. Will demand a return of my XT tomorrow!
Posted: Sun Aug 23, 2020 9:35 pm
by V-Tom
I got my replacement cable about two weeks ago (and replacement mount a month or two ago.)
The mount made the issue better but didn't solve it but since getting the new cable I haven't had a single power out.
..Tom
Posted: Mon Aug 24, 2020 5:50 am
by tourman
I bought a Zumo XT few weeks ago. Haven't had any issues. Should I contact Garmin to get a new connector? Do they charge for them?
Posted: Mon Aug 24, 2020 9:50 am
by sprint
tourman wrote: Mon Aug 24, 2020 5:50 am I bought a Zumo XT few weeks ago. Haven't had any issues. Should I contact Garmin to get a new connector? Do they charge for them?
If you only bought it a few weeks ago it will most likely have the updated mount already. If you look at the front face you should see what looks like a piece of horizontally mounted insulating tape between the bottom two fixing hole recesses. That, it seems, is just enough to provide a tight fit between the mount and the Sat Nav mounting face.
Posted: Mon Aug 24, 2020 11:05 am
by simoncrewe
The very early mounts that they changed under warranty has nothing to do with the pin issue that people are experiencing. The early mounts were allowing the main GPS unit to move slightly.
The pin breakage issue is even affecting people with very late model GPS units.
Posted: Mon Aug 24, 2020 7:47 pm
by Scarecrow
Hi follk
I'm considering a new unit either 595 or XT but wondered if Garmin have rectified the mount problem
Cheers in advance
Del
Posted: Tue Aug 25, 2020 9:21 am
by simoncrewe
The mount has not been a problem for quite some time. Some people still appear to be having problems with the pins on the main power lead.
Personally if I were you, I would not even consider a 595. The XT is light years ahead. You may not know this, but the 595 has a battery connection problem, that Garmin never sorted & is still ongoing. I sold my 595 pretty quickly in April when the XT came out, and very glad that I did.
Posted: Mon Aug 31, 2020 12:26 am
by crypkema
It appears the pin issue in the mount is not resolved yet. My lower pin is cocked at an angle. I get power to it, but the power doesn't connect with the GPS. I've put in a request via email for a warranty claim.
Chris
Posted: Mon Aug 31, 2020 5:45 pm
by Vespamarc
My idea is, that the connector problems coming from the protection hood. most people push too hard on this. Ans it is mostly the lower connector who gives problems.
I and other people who using a 3D printed protector, don't have any problems with the connector.
