It WAS all working fine, but then I did updates on everything. Cleared everything out and re-paired (as I thought).
Now the GPS gives directions and she interrupts our conversations. Not only that, but there is an annoying beep tone after the gps gives directions. It’s like the beep is indicating the we can only talk after the beep (after she’s done talking).
I don’t know if the problem is with the sena or with the gps.
I set it up so the the sena is multitasking. The gps is paired as a gps although I have tried other ways to pair.
Bluetooth connection is constantly being lost and my music then won’t play.
If you have any suggestions, I would greatly appreciate them.
TIA.
Two bikes, SENA 20s and 590LM on both - help :-(
- Site Admin
- Has liked: 435 times
- Been liked: 260 times
Re: Two bikes, SENA 20s and 590LM on both - help :-(
I have never used the sena's but on the cardo there is a setting to give priority to intercom or gps etc
Have you checked these settings?
