Garmin recommends to pair your phone with the zumo and the zumo with your headset - without a separate connection from your headset to the phone.
Basically: Phone <=> zumo <=> Headset
I've tried that with my 595 but noticed that this breaks the Google Assistant feature for me. E.g. when saying "Okay Google" to my Packtalk Bold, it wouldn't trigger the Google Assistant on my phone (because the trigger went to the 595 which didn't forward it). That's why I had to pair my phone and the 595 both to my Packtalk instead.
Could somebody with the XT and a headset with the assistant feature try if this works with the devices chained, now, please?
"Ok, Google" / "Hey Siri" from headset - does it make it to the phone?
- mbirth
zūmo 595LM + Cardo Packtalk Bold
Re: "Ok, Google" / "Hey Siri" from headset - does it make it to the phone?
Yes you lose the direct ability for "Okay Google." You can use the "Voice Call" function in the phone app to do the same thing (but you don't say "Okay Google".). You press the Voice dial button and when the screen says to speak you say your command. As far as I can see it will do anything you can do as if you were speaking directly to the phone. Downside is that it means a few key clicks and once you voice dial it goes out if the phone app so a few clicks to go back if you wanted to give another command.
If you take the XT out of the connections the Packtalk Bold works normally. (I tried it mid ride just to check.)
..Tom
..Tom
With an iPhone 11 and Freecom 4+ the situation is much the same, although I have to have the phone paired to the headset as well, because I use the XT only on one of my bikes. Whether the XT is involved or not, I need to press the phone button to be able to use voice commands with Siri. I have VOX disabled on the headset because it doesn't work well with my accent, so that may play a part.
- mbirth
Thanks a lot! So it's very much like with the 595.
Users browsing this forum: CommonCrawl [Bot], jfheath and 0 guests
