Audio warning issue
Has liked: 271 times
Been liked: 343 times
Re: Audio warning issue
Not saying this must explain the difference, but often with Garmin devices different locales have different options :D
Tac
Post by Tac »
I think this problem started with the 2.7 firmware update. I'm sure the change of speed limit alarms could be turned off before the update.
Hati
Been liked: 15 times
Australia
Post by Hati »
Tac wrote: 09 Jun 2020 16:18 I think this problem started with the 2.7 firmware update. I'm sure the change of speed limit alarms could be turned off before the update.
Not with Australian maps. The issue was there out of the box, as it came from Garmin.
Skipper
Sweden
Post by Skipper »
I have software version 2.7 and as I said in my earlier post it works just fine.
Tested it on the road again today.
2010 Vulcan 1700 CT (Nomad)
RV Kabe Travelmaster 880 LT Royal
Grispoil
Post by Grispoil »
Skipper wrote: 08 Jun 2020 17:06
And I can choose 20 over, 15 over, 10 over, 5 over, at the speed limit or OFF.
Also, choose differently for citytraffic or outside.
Where exactly are you getting these options?
I must have checked all menu items on my XT and I just cannot locate these...
Yvan
Worth repeating what I said above in case folks missed it. It's not unusual for different options to be available depending on which locale is selected, so just because one device has an option it doesn't mean they all do.
Has liked: 79 times
Been liked: 176 times
sussamb wrote: 10 Jun 2020 15:44 Worth repeating what I said above in case folks missed it. It's not unusual for different options to be available depending on which locale is selected, so just because one device has an option it doesn't mean they all do.
As I found recently, not all apps or options are available all the time depending on what settings are chosen.
Jefro
Has liked: 7 times
Post by Jefro »
Skipper wrote: 08 Jun 2020 17:06 I can turn all warnings off, including the speedwarning.
Got my XT last Thursday. And I can choose 20 over, 15 over, 10 over, 5 over, at the speed limit or OFF.
Skipper, can you tell us what menu page these options are listed on? Thanks.
Grispoil
Post by Grispoil »
Jefro wrote: 17 Jun 2020 16:03
Also Skipper, I see that you are from Sweden, what maps do you have installed on your XT?
simoncrewe
Has liked: 43 times
Been liked: 35 times
Post by simoncrewe »
Grispoil wrote: 10 Jun 2020 15:18
Yvan
Go to settings - Driver assistance - Speeding Alert - Inside the City / Outside the City
