Page 3 of 3
Re: CN EU 2020.30 NTU
Posted: Fri Jan 31, 2020 7:56 pm
by Wapping
I have a Mac running map version 2020.2 AND 2002.3
I can summarise the problem as follows:
If I create a fresh route A to B in 2020.2 I can switch and recalculate between 'Motorcycle' (a magenta line following roads, according to my preference settings) and say, 'Direct' (a straight magenta line A to B) at will, with absolutely no problems at all. I can go back and forth without a care in the world. But.....
If I then open the same route in 2020.3, I can switch it from 'Motorcycle' (magenta line follows the roads) into 'Direct' (straight line A to B) but I cannot then switch it back again; it stays as a straight line, no matter what I do. Nothing by way of recalculation or changing Activities will persuade it to be anything else but a straight line, A to B.
If I then go back into 2020.2 I can once more switch the same route between 'Motorcycle' and 'Direct' at will, the route alternating between conventional road following and a straight line, just as it should do.
In short, in 2020.3 once you get the straight line version of a route, you cannot then recalculate it (or do anything else) to get it back to a conventional route following the roads. The only way back is to switch back to 2002.2 maps.
Posted: Fri Jan 31, 2020 7:59 pm
by Wapping
sussamb wrote: Fri Jan 24, 2020 10:21 am
This seems like a Mac issue with the latest map, there are a couple of similar comments on the Garmin forum. It'll be worth phoning Garmin Product Support to report it.
It’s a Mac issue with 2020.3, without a doubt.
Posted: Thu Feb 20, 2020 5:47 pm
by Vespamarc
Garmin update Basecamp to 4.8.8 today. Works perfect with 2020.30 Maps, no more straight lines.
Posted: Tue Feb 25, 2020 7:04 pm
by alan sh
But does it work with Google Earth?
