I've noticed that when I make a route in basecamp and send it to my Zumo, many of the via points that I've made alert on arrival despite being selected not to do so in basecamp. The more via points I've used the more announcements I get on my Zumo when travelling the route to the point when it can drive me mad!!!
I've discovered that if I make a route, convert it to a track then back into a route I only get only two points, basically the start and finish.
Will the Sat Nav follow this route ok? I've sent the routes to my device and then looked at them again in basecamp and they seem to be ok
So if I make a route, convert it to a track then back into a route with only two points the start and finish do you think the Sat Nav will follow the route as its on the device or will it re-route it the most direct way. Guess it'll be trial and error, I'll need to make some routes and try them.
titter wrote: ↑02 Sep 2019 16:43
There is another way to make via points that will not announce on the Z550. In Basecamp if you shape the route using the Insert Tool (pencil icon) by clicking and dragging the route, and place the resulting via points PRECISELY in an intersection, the resulting via points will not announce on the Z550. This is actually true for any via points placed in an intersection or along a road without street addresses.
Breezly wrote: ↑04 Sep 2019 00:52
Ooh, I HATE doing that! I've found that placing points exactly on an intersection confuses me and the device because it wants to pass the point BEFORE giving me the turn instruction causing me to miss turns and on one occasion, nearly run right through a T intersection. I now
place points either well before or about a 1/2 mile after the intersection to avoid dying. Plus, in North Carolina's mountains, Base Camp is horrible at recognizing the difference between a bridge and an intersection. Much time can be spent going in circles b/c Base Camp wants to be under the underpass or on top of the overpass, neither of which I'm on.
rbentnail wrote: ↑04 Sep 2019 18:08
I have never experienced what you describe, but I generally would not place the via point at an intersection where I was turning. I would place the via point either at the preceding intersection or the succeeding intersection. Bridges and overpasses are not intersections so I wouldn't place a via point there anyways.
