anyone else have a bluetooth delay when using the garmin and a bluetooth headset.
when the zumo gives out there is a delay before the bluetooth connects to the headset sometime missing part of the first step of directions
if you have I have opened a case with garmin Reference ID: 14488322K1 if enough people have the problem the tech said they will definitely look into it
just call them and let them know and post here if you are having the same issue
