.... Just bought a new motorbike 2016 Africa Twin.. The dealer had installed a charging connection for a 520 satnav with a 4pin plug. My 345 has a 2 pin plug is there and adapter to change the 4 pin to two pin so I don't need to remove the present dealer installed cable. Thanks.
If I decided to cut the wires and solder the 2 pin onto the cable thats there anyone up on what to connect where.
Thanks
4 pin to 2 pin charging
mark.donald.5036
Re: 4 pin to 2 pin charging
I ended up fitting a new cable to a connection under the seat routed it to the dash area and its working perfect... No 4 pin to 2 pin that was a shot in the dark.
