Options for Mounting Zumo
Posted: Wed Jan 07, 2026 3:24 pm
I'm taking the opportunity to attempt to fit my camera, electrics and satnav to my new-to-me vehicle.
For the satnav - I've always liked it to be located on the fairing dash behind the screen, over to the left hand side. Out of immediate eye-line but easy to read with a quick glance.
Here is my 3rd Pan European with the RAM ball mounted and again with my old Zumo 660 mounted on the Ram Ball.
The top half shows the ram ball mount - which is mounted on a rubber cushion cut from an old inner tube and bolted through to a circular metal plate on the underside of the dash - also sandwiching a piece of Inner tube. It works really well.
My new bike - well, at present I am not so sure about how to get under that bit of the fairing at the moment - but even if I was, the dash plastic seem to be much more brittle than that on the ST1300.
So I am wondering about these RAM Ball Mounts. My 1300 has the lozenge shaped base. I'm wondering about using the circular one (which is what I had on my last 1300)
Rather than using my previous method, I am wondering about trying a different method
Eg:
Can these 3M strips take this behaviour, or is it likely to come unstuck.
Without a metal plate underneath - the weight is taken by the plastic around the well nuts.
Has anybody tried this method please.
And more to the point, if you did, did you lose your Zumo as a result, or did your fairing crack ?
Eg:
- Using 3M Heavy Duty Foam adhesive Pads to stick the circular base onto the plastic. I had pretty good success with this on my camera recorder box. Rather like a mobile phone, but half the length. I stuck it down to a piece of hardboard and secure the wires to it so that the wires could not vibrate against the body of the recorder at the point where they emerge. That worked well, but I've just tried to release it from its grip. IT took about quarter of an hour, gently prying and getting a thin blade to cut the adhesive. Maybe this worul work for the ramball ?
- Well nuts. These are rubber top-hat shape with a captive nut at the top of the hat. You drill a (say) 5mm hole. The not is pushed through the hole first until the brim of the hat is resting on the plastic. When you insert the bolt (hopefully remembering to put it through the RAM ball mount first) and screw it into the nut, the tightening process compresses the rubber so that there is in effect a big rubber washer between the nut and the plastic.
- Combination of both of the above.
