Hi all,
I will be traveling in India on a motorbike and would like to use my Garmin zumo XT. However an Indian map seems not to be available anymore on the garmin website. can someone advise me if it is even posible to get an indian road map onto the zumo xt and use for navigation???
thanks for your help.
Map for india???
Re: Map for india???
- lkraus
- Has liked: 87 times
- Been liked: 248 times
John pointed to my usual source for good maps, but I am surprised to see that there are none for India.
Try https://wiki.openstreetmap.org/wiki/OSM ... n/Download for links to a couple of other OSM sources which do claim to have India maps. I would suggest downloading both and seeing which works best for your needs.
Hello Remie. Using MakeGmap https://github.com/FrankBijnen/MakeGmap/releases you shold be able to create one yourself.remieboom wrote: Sun Nov 02, 2025 6:44 pm Hi all,
If you need help, send me a PM, I'll be glad to.
Frank
PS: Ik ben ook NL, dat maakt het miscchien makkelijker. (I'm also Nl, may make things easier)
