Is there anyone who knows about this and can give me advice? Many thanks in advance.
BaseCamp shows the route as a straight line
SveinHaakon
- Has liked: 1 time
- Been liked: 2 times
I am creating a simple route in BaseCamp, but the route comes up as i straight line, regardless of which map I am using.
- A simple route from Hirtshals to Flensburg comes up as a straight line.
- BaseCamp-screenshot.jpg (120.75 KiB) Viewed 902 times
Re: BaseCamp shows the route as a straight line
It will be because route properties is set to direct. Open route properties by right clicking on the route in the left hand pane and select Open, change route activity to something other than direct in the drop down box top right.
SveinHaakon
- Has liked: 1 time
Thank you for quick answer, but the activity is already set to Motorcycling, not Direct. So I believe there must be something else.
- lkraus
- Has liked: 87 times
- Been liked: 248 times
That looks like the Global Map included with Basecamp, which is not routable. Try switching to a City Navigator map and recalculate.
SveinHaakon
- Has liked: 1 time
Thank you very much indeed, the case is solved. I had switched to City Navigator, but I had not pushed the button for recalculate.
Now you have saved me a lot of work, I thank you again, and wish you a continued good Sunday.
Best regards
SveinHaakon
Oslo, Norway
Best regards
SveinHaakon
Oslo, Norway
- Has liked: 119 times
- Been liked: 267 times
Good deal! Even I, way over here in the USA, breathed a sigh of relief for you!
Anytime you switch map you need to recalculate. You may find this tutorial useful https://www.newenglandriders.org/learn-basecamp/SveinHaakon wrote: Sun Aug 31, 2025 4:03 pm Thank you very much indeed, the case is solved. I had switched to City Navigator, but I had not pushed the button for recalculate.
Best regards
SveinHaakon
Oslo, Norway
