High-quality RAM mount alternatives from FANAUE
Wondering how to mount your Garmin Zumo? feel free to ask in here or even show off your mounting method.
Has liked: 39 times
Been liked: 97 times
Germany
Post by proofresistant »
High-quality RAM mount alternatives with a very good quality/price ratio can be found with products from FANAUE.
I can only recommend you to take a look there.
The parts are impressive and I have never been disappointed.
My first rather orders were from Amazon I found something by luck there.
Later then I preferred to order from the Far East store AliExpress (no problems, just a bit of a wait).
FANAUE is not extremely cheap, but it is definitely not "Chinese" junk.
In comparison, I find them better than the “originals”
bicyclenut
Been liked: 3 times
Re: High-quality RAM mount alternatives from FANAUE
Post by bicyclenut »
I would recommend Tackform mounts. They use a ball mount system similar to RAM but they are smaller 20mm ball size and almost all of their mounts are metal and not plastic. The RAM balls can deform over tie and Tackform does not. They have may more mounts and arms to select from than RAM and the smaller size is nice to work with. The AMPS mount standard means you can use them with most GPS mounts and they have many options to create custom mounts. www.tackform.com
Zumo XT2
Zumo XT
BMW NAV 5
Navigating my BMW R1200RT
