It has been reported before that routes reappear in XT2 devices even though all routes were previously deleted (XT2 and or Tread app and or Explore).
I've just noticed it more as my experience with tripmanager grows.
I'm not saying it's related to Tripmanager, quite the opposite, thanks to Tripmanager I noticed it the quickest which could be the reason.
The reason for the routes reappearing is probably that the XT2, for whatever reason, perhaps creates duplicates of the “trips” when synchronizing (sync. issues).
Found in:
zūmo XT2\Internal Storage\.System\Trips\1234567890.TRIP
There were some copies of trips, different file name, different number of copies, may different route sources but recognizably the same content per route source.
(For me, the *.trip copies from the same route source all look the same, even the Tripmanager CSV export does not show me any different content).
If I then restart the XT2, supposedly without existing routes, the first trip file found always comes back as a route in the XT2 visible in the Explore routes library.
What is still strange is that I can then see the trips as a route in the XT2, but not in the Tread app, even after synchronization.
Then I can also edit the route in the XT2.
But then, as if by magic, the route in the XT2 disappears again and there is one less file in the Trips folder.
If I then restart the XT2, the first trip found appears again as a route until all trips in the folder zūmo XT2\Internal Storage\.System\Trips\ have been removed, which can of course also be deleted on the PC.
Has anyone observed this?
Anyway, the knowledge about the trip copies now helps me to clean up the XT2
PS
@ @FrankB : Could you think about, displaying an additional column with the trip name (mTripName) in the TripManager table with the trips?
(I personally find the trip name more interesting than the file name anyway)
